Customize BreadCrumbs
Vimaleswary Sugumar
August 29, 2012
In Atlassian Confluence, the breadcrumbs are generated based on the page's hierarchy. I have got a requirement to display breadcrumbs based on the navigation. Do you know a plugin, to generate breadcrumbs based on navigation the user does instead of based on content's hierarchy.
Vimala
Matthew J. Horn
January 30, 2013
I don't know of a plugin. However, the place to start would be the breadcrumbs.vm file in the /confluence directory. It uses Velocity, so if you can get, say, the previous page from within Velocity, then you can make that your breadcrumb.
