Default Macro Metadata Provider won't start
Hassard December 4, 2013
Macro plugin won't start so user macros are all emtpy
Hassard January 23, 2014
I rememeber now, it was the adaptavist content formatting macro that broke everything :(
Hassard January 6, 2014
You will have a plugin that is not compaitable with the version of confluence you are runnning. I removed an out of date plugin from the UPM and all worked fine again.
Julia Wester December 21, 2013
i have the same issue. The system plugin is disabled and I don't have an option to enable it.
Register now
