I need some help with the following task:
The specific problem would be: If the value Standard Change is specified on one side, only one of the values may be specified elsewhere
• pure copybook release;
• Low-risk operational disruptions;
• small, low-risk changes;
• Technical releases without impact on banking applications;
• program deletion;
• CPU optimization;
• Sonarcube code optimization;
• Removal of "dead" code;
• Easy, low-risk, client-specific code customization;
• Exchange interface.
to be chosen. This dependency could be solved, for example, by using two linked selection lists.
Another tip was to solve that with variables, I don`t know how to do that, any advice would be appreciated.
Kind regards
Chris
