Difference between 2 dates - how to?
Rumceisz
Hi All,
we have Reporting plugin which enables to calculate the difference between two dates. Do you know how to achieve this? We don't find any docs for this.
We need the difference in days or month.
Thanks in advance,
Rumi
CelesteCS
Hello!
For any calculations in Confluence, including calculations over tables, you may use CelesteCS Math for Confluence. There are versions for both Confluence Server and Confluence Cloud.
Assume you have a table with three rows and four columns: A till D with two rows and want to summarize elements from B2 to D2. Then here is the formula you should specify in A2:
SUM(Table1.B2:D2)
If you want to calculate average value, use AVG function:
AVG(Table1.B2:D2)
As you see, it is very simple and is similar to EXCEL with equal set of functions.
There is a plenty of other functions in the macro, so you may perform any calculations using formulas in EXCEL style.
Yagnesh Bhat
July 16, 2014
If you are planning to write a plugin to do this, then you can have that plugin have a macro in it that takes two dates as parameters and calculates their difference. To calculate this difference , you can use the Joda API that already comes bundled within the confluence plugin package. More about this here : http://www.joda.org/joda-time/
atlassian, confluence whiteboards, whiteboard templates, template contest, visual collaboration, atlassian learning, confluence community, brainstorming tools, agile planning, team productivity, confluence templates, share your template
Share Your Confluence Whiteboard Template for a Chance to Be Featured in the Product! 🏆
Want to leave your mark on Confluence? One winner will have their whiteboard design added into Confluence for all users to access! This is your chance to showcase your creativity, help others, and gain recognition in the Confluence community.
Share your template today!
