I set up an home page for our Confluence installation that lists the top level pages for every space. The wiki is open for guest users but some space content must be visible only to registered users.
If I use the Page Tree macro, anonymous user are forced to login in order to display the page.
If I use the Children macro, I get this message "Unable to render {children}. Page not found: CS:Configurazioni Server."
Is there a way (native/plugin/macro) to display an alternative text if there's some kind of authorization limitation over the content?
For example, something like "To visualize this content you need to be logged in".
The Customware Visibility Plugin is great for this. We have it set up to display a disclaimer to people who aren't logged in (i.e. Annonymous) which users who are logged in won't see.
And it's free!
https://marketplace.atlassian.com/plugins/net.customware.confluence.plugin.visibility
Thank you :-) This plugin should solve my problem, but I think it's not compatible with the latest version of Confluence. I tryed installing it but I got this error
Plugin installation failed: Failed to resolve plugin dependencies within OBR [plugin_6327012005172267721_visibility-plugin-2.1.0.obr]
I'm using Confluence 5.2.3
As of today (9/11/2013) it's listed as compatible with 5.1.5 and below.
Although you might want to try and install it using confluence's hidden plugin screen. I usually have better luck installing plugins from here. Sometimes the regular Manage Add-on screen just craps out.
http://yourdomain/admin/viewplugins.action
Sean King - how do you have the Visibility plugin only show to Anonymous users? I put "anonymous" as the user or group, and it doesn't display to non-logged in users.
David Hergert - You can use the "hide if" macro with confluence-users added to the user group to hide from anyone logged in. You can then use the "show if" with the same group added to do the opposite and only show to people logged in.
@Sean King1 - I tried your approach but it didn't work for me. I did a "hide-if" set to "any" and "confluence-users" on an anonymous page, no luck. Any ideas?
You could set the global permissions to allow anonymous access to the site, then set each space permission to disable anonymous viewing.
This is what I did, but if I insert in the home page a Page Tree macro that lists the top level pages of a restricted space, anonymous users are forced to log in.
Help us plant more trees
