[Docker] How to build with Oracle
thesefer
I have seen 6.5 requires oracle jdk/jre but the Dockerfile/Container provided uses openjdk which is not supported.
You would have to build it yourself but this is not possible as described at
https://confluence.atlassian.com/confkb/update-the-confluence-docker-image-to-use-oracle-jdk-829062521.html
because the source doesn't exists.
Step 1/20 : FROM oracle/JDK:8
invalid reference format: repository name must be lowercase
alternative
Step 1/20 : FROM oracle/jdk:8
pull access denied for oracle/jdk, repository does not exist or may require 'docker login'
I found another thread but the source doesn't exists either.
https://community.atlassian.com/t5/Questions/How-to-update-the-official-Confluence-Docker-image-to-use-the/qaq-p/459509
Step 1/20 : FROM oracle/serverjre:8
pull access denied for oracle/serverjre
 So how do you proceed from here?
Edwin Kyalangalilwa
November 11, 2017
You can use airdock/oracle-jdk
https://hub.docker.com/r/airdock/oracle-jdk/
thesefer
possible but now one has to fiddle around with missing packages which are alpine-only for reasons... guess there is a lot of work neccessary... thanks.
Still, the support article seems wrong and should be updated
atlassian, atlassian community, job interviews, interview tips, career advice, interview preparation, job search, interview experiences, hiring process, atlassian careers, community discussion, interview best practices
Interview Tips & Pet Peeves ✍️
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!
