Does a ten users Starter License allow to export spaces?
Peter Dyballa January 10, 2020
Hello!
This is my question: Am I (technically/legally) allowed to export s space (as PDF, XML, HTML) in order to save it and maybe import it into another Confluence instance or is it a bug that I cannot see any means to export a space?
When I visit the spaces directory the cog menu shows no entry related to export, just the usual configure, admin, and apps entries.
Greetings
   Pete
DPKJ
@Peter Dyballa  You will need admin permissions to export space.
To export space,
- Click Cog-Icon on bottom-left side screen (when you are on any page of space, in side bar)
- Select Content Tool (if this is not visible, you are not administrator)
- Select Export in desired format
You also reach this page by this link, <CONFLUENCE_BASE_URL>/spaces/exportspacewelcome.action?key=<SPACE_KEY>
Thank you very much, DPK! That's it: I have to choose the proper cog…
Greetings
  Pete
