×The drag and drop facility and tasklist features have stopped working on my Confluence instance.
As the System Administrator I've not disabled or changed any settings to to prompt the above changes.
Would anyone know what may have prompted these features from working and if so, is there a solution?
Confluence Version: 3.5.2
If you are using Firefox, and you have recently updated to v7 or v8, then that would explain the drag and drop problem. See https://jira.atlassian.com/browse/CONF-23360. This should be fixed in an upcoming release.
I'm not sure what's happening with the Tasklist - it works fine on http://confluence.atlassian.com, however I found a bug report which sounds similar to your problem: https://jira.atlassian.com/browse/CONF-24051. If you can provide any further details, please add them to that issue.
Mark
