Duplicate site names possible?
Björn Eitmann
Hi *
Is there a setting to allow duplicate site names, by permalink url or something like that?
BR
Björn
Jennifer S
The Scroll Versions plugin https://marketplace.atlassian.com/plugins/com.k15t.scroll.scroll-versions allows duplicate page names within a Space by using permalinks, but it is a paid plugin.
CharlesH
January 9, 2013
I think you can have duplicate space names, provided the space key is different.
As for pages, then within a space these must be uniquely named as Nic suggests.
Nic Brough -Adaptavist-
January 9, 2013
Ooops, thanks CharlesH, yes, I should have said that pages have to be uniquely named *within a space*. You can have lots of pages called FRED in your confluence, as long as each one is in a different space.
JamieA
January 9, 2013
The (rubbish) workaround is to add a trailing space to the title...
January 9, 2013
By "site", do you mean "Confluence space"? If so, then no. You can create links and redirects that all point to one place, but you cannot have duplicate space names. How would a browser know which one you meant if you had two?
January 9, 2013
Ok, but the answer is the same - no, because you could not know which page to serve up if there are two with the same name.
Björn Eitmann
I mean page names.
January 9, 2013
Register now
