Duplicating form fields using confi form
Confi User June 15, 2022
I was wondering if its possible to repeat some form fields if a certain button is clicked and duplicates it down for them to enter another set of data.
 For example:
We have 3 form field that are that are Product ID, Product Expiry, and Product Issue. I want to repeat this form depending on the number of products the user wants to enter. He could do this by pressing a "+" sign or whatever the mechanism comes out to.
How would you implement this on confi forms?
Alex Medved _ConfiForms_
Hi
Take a look at the ConfiForms Smart multi-row field
https://wiki.vertuna.com/display/CONFIFORMS/ConfiForms+Smart+Multi-row+-+what+it+offers+and+how+to+use+it
It feels like it offers exactly what you are looking for
Alex
Confi User June 16, 2022 edited
Hey Alex,
I don't see the Smart Multi-row field in the form field definition. Will this option appear after following the tutorial, or should it have already been there?
edit: Just got updated that our confluence is hosted on the server, so this option won't work. Is there anything else you can recommend Alex?
Hi
This field type is available for both - cloud and setver/dc versions, unless you are using some old version on your server instance (in this case then just update the plugin)
Alex
Confi User June 17, 2022
Thanks for the help Alex, I wasn't able to enable the setting, but I found a work around :)
Like • Alex Medved _ConfiForms_ likes this
