ERROR: called with no current PropertyPanel +The given range isn't in document.
AustinS January 25, 2018 edited
Im developing a customized macro and found these errors during testing.
 Steps to reproduce the problem:
  1. Insert macro
  2. save it
  3. edit it and chose "cancel"
  4. delete it from page
  5. trying add a new same macro w/ different params on the same position
  6. no macro be inserted
Monitor in console, see errors:
  • The node to be replaced has been already deleted from the document ;
  • PropertyPanel.destroy: called with no current PropertyPanel, returning;
  • The given range isn't in document
Using TinyMCE and Confluence version is 6.3.1
Any help would be greatly appreciated.
AustinS February 1, 2018
I found it is bug from TinyMCE version 3, which is used in Confluence 6.3.1 and it has been fixed in new version. (https://www.tinymce.com/docs/changelog/#version456-march302017 )
But it has been fixed in version 4 and this version will be used in Confluence 6.6 (https://developer.atlassian.com/server/confluence/preparing-for-confluence-6-6/).
AnnWorley
February 1, 2018
If you are all set I will mark your question as answered. Please let me know if we can help with anything else.
Upcoming Confluence Events
