EasyMind was deaktivated after upgrade to 1.4.5 on Confluence 5.4.3?
Arne Herbert
March 4, 2015
After Upgrading EasyMind to Version 1.4.5 on Confluence 5.4.3, accured an error, and easymind was deaktivated. What's the problem, is there an Issue regarding this Versions? What can be done to fix the Problem?
Deividi Luvison
March 4, 2015
Hey Arne,
What happens if you try to re enable the plugin? DO you get any errors on the UI or logs?
If that does not help try clearing Confluence plugin Cache, if that still fails then one last option would be to backup your instance, un install the add on and install the previous release so you can use your add on while the plugin owner investigate this problem.
Hope it helps.
Thanks and Regards,
David| The Engineer that like Windows for realsies.
