Enable SSL with AWS ELB and Confluence
Troy Moreland
I am successfully running Confluence (and Jira) in AWS behind ELB (elastic load balancer) instances.  On the ELB there is an HTTP (80) listener to the EC2 instance on the HTTP port for Confluence (8090).  This works great.  However, I want to use SSL on the ELB side.  When I change the listener on the ELB that works but Confluence redirects back to port 80 which then fails since the ELB is no longer listening on that port.  I tried changing the base URL and I tried adding proxyPort to the server.xml file.  I haven't found a combination that works.
Brian Harris
March 20, 2017
Tom Jackson
December 12, 2016
I got this working. The key is in fact your server.xml. I use the following xmlstarlet commands in my Confluence dockerfile to inject the needed attributes:
# configure Confluence for use behind an ELB by adding proxy-related attributes to server.xml
RUN xmlstarlet ed --inplace --insert "/Server/Service/Connector" --type attr -n scheme -v https $CONFLUENCE_INSTALL/conf/server.xml
RUN xmlstarlet ed --inplace --insert "/Server/Service/Connector" --type attr -n proxyPort -v 443 $CONFLUENCE_INSTALL/conf/server.xml
RUN xmlstarlet ed --inplace --insert "/Server/Service/Connector" --type attr -n secure -v true $CONFLUENCE_INSTALL/conf/server.xml
Milind Shah
December 12, 2016
I tried that out but it did not work.
i updated the server xml to include the 3 variables mentioned adove but that still does not let https work through AWS ELB
Load Balancer Protocol
Load Balancer Port
Instance Protocol
Instance Port
Cipher
SSL Certificate
HTTP80HTTP8080N/AN/A
HTTPS443HTTP8080 3a9009dd-7216-458e-8b65-9e2cdf9ae24b (ACM)
Server XML:
<Service name="Catalina">
<Connector port="8080"
maxThreads="150"
minSpareThreads="25"
connectionTimeout="20000"
enableLookups="false"
maxHttpHeaderSize="8192"
protocol="HTTP/1.1"
useBodyEncodingForURI="true"
acceptCount="100"
disableUploadTimeout="true"
redirectPort="8443"
scheme="https"
proxyPort="443"
secure="true"
Milind Shah
December 12, 2016
HI Troy, Were you able to get this to work based on the link provided below by Renato?
I have a similar setup, where ELB port 80 points to instance port 8080 for JIRA, however the same does not work when setting up a https port via ELB and using a AWS Certificate.
Please let me know
Milind Shah
Tom Jackson
May 11, 2015
@Troy Moreland, did you get this to work?
rrudnicki
January 2, 2015
Hi Troy,
I believe it is failing because your ELB is listening on port 443 but when Confluence send the information back, it is done by a different port. So, the ELB receive the connection from Confluence on port 80 when the expected is on port 443. So, I believe that if we configure Confluence to only listen on port 443 it should works. Can you have a look on  this link and let us know how it is going?
In case it doesn't work, please paste the server.xml here.
Renato Rudnicki
