Enable an Speakeasy extention for all users
Andreas Precht
September 5, 2011
Hi there,
we need a way to enable some speakeasy-extentions for all confluence-users as an confluence-administrator or Server-Administor till there is an option to configure this. Our user should have some features with their first login, without to have enable theses by themthelf.
Does anybody knows a workaround?
Andreas
3 votes
Don Brown [Atlassian]
September 12, 2011
As I believe you found, there is an open issue for this feature: https://studio.atlassian.com/browse/SPEAKEASY-101
Focusing on the transition from user-enabled extension to proper extension/plugin is something I plan on focusing on probably around the October timeframe. In the meantime, you are always welcome to fork and submit a pull request.. :)
EDIT: This feature has been implemented in trunk and will be part of the 1.3 release.
Andreas Precht
September 12, 2011
October would be a great timeframe. We're going to launch our portal in november, so October is great. Then we're sure that all users can use the pulled the extentions with their first login.
Thanks a lot.
JamieA
September 12, 2011
AFAIK the changes required to convert a speakeasy extension to a proper plugin are pretty small. So if you want it available to everyone, sounds like you should convert it to a full-fledged plugin.
