Enable the Confluence Document Conversion Library
Robert McAllister September 10, 2018
I followed the instructions here to enable previews of documents. The instructions are good... up until enabling the add-on. Enable/Disable does not exist for the Confluence Document Conversion Library.
Using Confluence Cloud
Help!
https://confluence.atlassian.com/confkb/office-attachments-cannot-be-previewed-in-confluence-new-file-preview-847448358.html
Shannon S
September 12, 2018
Hi Robert,
This article is for Confluence Server (specifically version 5.8.5 but may also cover later versions of Confluence Server).
My recommendation is if you're having issues with previous in Confluence Cloud that you reach out to the support team, as they have access to your instance and can see what the problem is.
When reaching out, be sure to include if the preview doesn't work for all documents, only specific ones, and if you're able to replicate the problem in all browsers (not only Chrome or Edge, for example.)
Shannon
Robert McAllister September 12, 2018
Thank you Shannon. It appears that the cloud functionality has returned without any adjustments made on my part. Maybe a glitch in the system...
Shannon S
September 13, 2018
Glad to hear, Robert! It's likely someone discovered it as well and rolled out a fix in the meantime.
Take care,
Shannon
