Enabling https with Confluence
Onno van der Straaten
There is some documentation on how to enable https with Confluence for example https://confluence.atlassian.com/doc/running-confluence-over-ssl-or-https-161203.html
When I follow these instructions I cannot access the site. When I navigate to my test instance I see in the browser
Secure Connection Failed
An error occurred during a connection to collab:8443. Cannot communicate securely with peer: no common encryption algorithm(s). Error code: SSL_ERROR_NO_CYPHER_OVERLAP
Nmap shows the ciphers as shown below. The ciphers look a bit strange to me. When I check for example ciphers from other sites I see more and other ciphers. And there is no overlap.
Is it possible to enable https this way? Should I use a different Java - not the embedded jre?
[user@xtop:~] $ nmap --script ssl-enum-ciphers -p 8443 collab
Starting Nmap 7.60 ( https://nmap.org ) at 2019-07-04 09:58 PDT
Nmap scan report for collab (1.1.1.12)
Host is up (0.00042s latency).
PORT STATE SERVICE
8443/tcp open https-alt
| ssl-enum-ciphers:
| TLSv1.2:
| ciphers:
| TLS_DHE_DSS_WITH_3DES_EDE_CBC_SHA (dh 2048) - C
| TLS_DHE_DSS_WITH_AES_128_CBC_SHA (dh 2048) - A
| TLS_DHE_DSS_WITH_AES_128_CBC_SHA256 (dh 2048) - A
| TLS_DHE_DSS_WITH_AES_128_GCM_SHA256 (dh 2048) - A
| TLS_DHE_DSS_WITH_AES_256_CBC_SHA (dh 2048) - A
| TLS_DHE_DSS_WITH_AES_256_CBC_SHA256 (dh 2048) - A
| TLS_DHE_DSS_WITH_AES_256_GCM_SHA384 (dh 2048) - A
| compressors:
| NULL
| cipher preference: client
| warnings:
| 64-bit block cipher 3DES vulnerable to SWEET32 attack
|_ least strength: C
Nmap done: 1 IP address (1 host up) scanned in 0.48 seconds
[user@xtop:~] $
Stephen Sifers
July 8, 2019
Hello Onno,
Thank you for including the steps you took and the output from your tests. This type of error can be caused by the certificate that was used/generated. We would suggest reviewing your created certificate and ensure it is using RSA which is supported by default. If you’re needing a cipher outside of RSA we would suggest reviewing the following; Security tools report the default SSL Ciphers are too weak.
I hope this information proves helpful and you’re able to resolve or address your cipher issues.
Stephen Sifers
