Encoding problem while exporting pdf
Nevin Cansel February 15, 2022
We have Confluence Data Center and when I want to export pdf, turkish characters are exported as question mark.
I changed font to Arial which supports turkish language but nothing has changed. I added properties to Tomcat which are
-Duser.language=en
-Duser.country=US
-Duser.variant=US
-Duser.timezone=Asia/Istanbul
-Dfile.encoding=utf-8
-Dsun.jnu.encoding=UTF-8
but the result is same.
When I export to word, everything works fine but how can I export pdf with proper characters?
undefined
Thanks in advance!
Nevin Cansel March 14, 2022
Could I possibly get support from Atlassian team?
Nevin Cansel March 1, 2022
Aron Gombas _Midori_
I think it isn't an encoding problem, but the font Confluence uses to create your PDF doesn't contain the Turkish character glyphs.
Make sure that you uploaded a font file which does!
See: https://confluence.atlassian.com/doc/create-a-pdf-in-another-language-175473.html
Hi Aron,
I tried at least 4 different fonts that contains Turkish characters but it did not work. That is why I thought it might be an encoding related issue.
Nevin Cansel February 28, 2022
Any other solution?
If you can't get the built in PDF export feature working, you could try the PDF exporter apps. Maybe those will work better...
Thanks for advice but I prefer to use build-in feature.
atlassian, confluence, marketing templates, confluence templates, marketing project management, content strategy, campaign planning, marketing collaboration, confluence for marketers, atlassian learning, marketing workflows, confluence best practices
5 must-use templates for Marketing teams (from a Confluence Marketer!) 👩🏻‍🎨
Read more 📚
