Error caused by atlas-create-jira-plugin
Shinal Pala June 1, 2020
I have just started working my way through Create a HelloWorld plugin project - https://developer.atlassian.com/server/framework/atlassian-sdk/create-a-helloworld-plugin-project/
I have just installed Atlassian SDK and added it to my classpath and I Java 8 on my machine.
When I type atlas-create-jira-plugin it returns the following error in the command prompt:
[ERROR] Failed to execute goal com.atlassian.maven.plugins:jira-maven-plugin:8.0.2:create (default-cli) on project standalone-pom: Execution default-cli of goal com.atlassian.maven.plugins:jira-maven-plugin:8.0.2:create failed: Plugin com.atlassian.maven.plugins:jira-maven-plugin:8.0.2 or one of its dependencies could not be resolved: Failed to collect dependencies at com.atlassian.maven.plugins:jira-maven-plugin:jar:8.0.2 -> com.atlassian.maven.archetypes:jira-plugin-archetype:jar:8.0.2 -> org.twdata.maven:mojo-executor:jar:2.3.0 -> org.apache.maven:maven-core:jar:3.5.4 -> org.apache.maven:maven-model:jar:3.5.4 -> org.apache.commons:commons-lang3:jar:3.8.1: Failed to read artifact descriptor for org.apache.commons:commons-lang3:jar:3.8.1: Could not transfer artifact org.apache.commons:commons-lang3:pom:3.8.1 from/to atlassian-public (https://maven.atlassian.com/repository/public): Not authorized by proxy , ReasonPhrase:Proxy Authorization Required. -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginResolutionException
Any idea why this is the case?
repi
June 1, 2020
@Shinal Pala
"Any idea why this is the case?"
[ERROR]
[ERROR]
Ivana Srebrenova December 15, 2022
Is there any solution on the problem above?
Thank you
