Error in creating application link between Jira and Confluence
Lipun
November 24, 2017 edited
Hi ,
Application link is between Jira and Confluence is creating successfully but it is not listing in the application list in Jira while the same is visible and status is connected in Confluence side.
Error : /rest/applinks/1.0/listApplicationlinks [core.rest.ui.ListApplicationLinksUIResource] Exception:
java.lang.RuntimeException: java.util.concurrent.ExecutionException: java.lang.IllegalArgumentException: host must not be null
at com.atlassian.applinks.core.rest.ui.ListApplicationLinksUIResource.collectApplicationLinkStateResult(ListApplicationLinksUIResource.java:232)
at com.atlassian.applinks.core.rest.ui.ListApplicationLinksUIResource.getLinkAndAuthProviderEntity(ListApplicationLinksUIResource.java:162)
at com.atlassian.applinks.core.rest.ui.ListApplicationLinksUIResource$2$1.callWithContext(ListApplicationLinksUIResource.java:250)
at com.atlassian.applinks.core.rest.ui.ListApplicationLinksUIResource$2$1.callWithContext(ListApplicationLinksUIResource.java:244)
at com.atlassian.applinks.core.rest.ui.ListApplicationLinksUIResource$CurrentContextAwareCallable.call(ListApplicationLinksUIResource.java:285)
at com.atlassian.sal.core.executor.ThreadLocalDelegateCallable.call(ThreadLocalDelegateCallable.java:42)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.util.concurrent.ExecutionException: java.lang.IllegalArgumentException: host must not be null
at java.util.concurrent.FutureTask$Sync.innerGet(Unknown Source)
at java.util.concurrent.FutureTask.get(Unknown Source)
at com.atlassian.applinks.core.rest.ui.ListApplicationLinksUIResource.collectApplicationLinkStateResult(ListApplicationLinksUIResource.java:224)
... 10 more
Jira gadgets are also not available in confluence side.
Jira Version : 6.2.7
Confluence Version :6.3.1
miikhy
November 29, 2017
I'm pretty sure you're facing an issue which is already known and good news is that here's a workaround!
Here is the knowledge base article to help you fixing that: https://confluence.atlassian.com/kb/cannot-retrieve-link-and-provider-entity-when-creating-application-link-827117142.html
The idea is that your Jira version is using a different version of SAL (Core component) than your Confluence version and it's known to cause issues with Tomcat. All details are explaine in the KB Article, hope you'll be able to troubleshoot that!
Cheers
atlassian, atlassian community, job interviews, interview tips, career advice, interview preparation, job search, interview experiences, hiring process, atlassian careers, community discussion, interview best practices
Interview Tips & Pet Peeves ✍️
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!
