Updating from 5.7 to 7.X and setup a Dev environment to test. After upgrade to 7.x we are getting this error on some pages that work in Prod:
Error rendering macro 'sql-query'
Unable to load database driver: net.sourceforge.jtds.jdbc.Driver. Make sure your configuration is correct.
I have found this error in posts but not an answer.
Any help is appreciated.
The net.sourceforge.jtds.jdbc.Driver is no longer supported since confluence version 6.4.
@Seth Howard , you will need to update the app settings to use the new driver instead of jtds as mentioned by @repi
Right now it reads :
<property name="hibernate.connection.driver_class">com.microsoft.sqlserver.jdbc.SQLServerDriver</property>
Is that incorrect?
Thank you all for your help.
Does the whole ENU folder go in the /bin directory or just the jre*.jar files?
Sorry I am asking for the hand holding but I cannot figure out quite what I am doing wrong.
Thanks again!!!!
Don't need to sorry :)
You should copy only the jtds-1.2.2.jar file under <Confluencei nstall-directory>/lib folder;
You can get this jar file from https://sourceforge.net/projects/jtds/files/jtds/1.2.1/
you will need to download jtds-1.2.1-dist.zip , extract it and then copy the jtds-1.2.2.jar into the <Confluencei nstall-directory>/lib
And then you will need to restart the application.
We came across the same error after we upgraded Wiki from 7.13.7 to 7.19.16 recently. Is this the same issue related to jdbc driver?
