Error when doing a dry release:build
Shinal Pala April 13, 2021
I have created a plugin and moved from using confluence version 6.10.13 to 7.4.6 by changing the confluence.version property in the pom.xml file.
I have recreated my local test fixtures and cleaned/built/started confluence locally successfully.
After committing my code changes to the central repository i attemted a dryrun of the release build and I keep getting the following error:
[INFO] [INFO] [talledLocalContainer] 2021-04-12 09:30:51,196 ERROR [main] [com.atlassian.threadlocal.BruteForceThreadLocalCleanup] logErr Thread[Caesium-1-2,5,Caesium-1] created a ThreadLocal with key of type [org.springframework.core.NamedThreadLocal] (value [Current aspect-driven transaction]) and a value of type [null] (value [null]). This will be cleaned up
[INFO] [INFO] [talledLocalContainer] 2021-04-12 09:30:51,200 ERROR [Caesium-1-2] [plugins.edgeindex.job.EdgeIndexQueueFlusher] lambda$null$0 Error performing index task: com.atlassian.confluence.plugins.edgeindex.lucene.tasks.ReIndexPermissionsIndexTask@2b6d4172
[INFO] [INFO] [talledLocalContainer] org.eclipse.gemini.blueprint.service.importer.ServiceProxyDestroyedException: service proxy has been destroyed
[INFO] [INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceDynamicInterceptor$ServiceLookUpCallback.doWithRetry(ServiceDynamicInterceptor.java:101)
[INFO] [INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.importer.support.internal.support.RetryTemplate.execute(RetryTemplate.java:81)
[INFO] [INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceDynamicInterceptor.lookupService(ServiceDynamicInterceptor.java:427)
[INFO] [INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceDynamicInterceptor.getTarget(ServiceDynamicInterceptor.java:400)
[INFO] [INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
[INFO] [INFO] [talledLocalContainer] at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
[INFO] [INFO] [talledLocalContainer] at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:136)
[INFO] [INFO] [talledLocalContainer] at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:124)
[INFO] [INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70)
[INFO] [INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
[INFO] [INFO] [talledLocalContainer] at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
[INFO] [INFO] [talledLocalContainer] at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
[INFO] [INFO] [talledLocalContainer] at com.sun.proxy.$Proxy2384.getById(Unknown Source)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.plugins.edgeindex.lucene.tasks.ReIndexPermissionsIndexTask.doReindex(ReIndexPermissionsIndexTask.java:73)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.plugins.edgeindex.lucene.tasks.ReIndexPermissionsIndexTask.lambda$perform$0(ReIndexPermissionsIndexTask.java:62)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.sal.core.transaction.HostContextTransactionTemplate$1.doInTransaction(HostContextTransactionTemplate.java:21)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.sal.spring.component.SpringHostContextAccessor.lambda$doInTransaction$0(SpringHostContextAccessor.java:70)
[INFO] [INFO] [talledLocalContainer] at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:140)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.sal.spring.component.SpringHostContextAccessor.doInTransaction(SpringHostContextAccessor.java:68)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.spring.transaction.interceptor.ConfluenceSpringHostContextAccessor.access$001(ConfluenceSpringHostContextAccessor.java:21)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.spring.transaction.interceptor.ConfluenceSpringHostContextAccessor.lambda$doInTransaction$3(ConfluenceSpringHostContextAccessor.java:72)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.impl.vcache.VCacheRequestContextManager.doInRequestContextInternal(VCacheRequestContextManager.java:84)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.impl.vcache.VCacheRequestContextManager.doInRequestContext(VCacheRequestContextManager.java:68)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.spring.transaction.interceptor.ConfluenceSpringHostContextAccessor.doInTransaction(ConfluenceSpringHostContextAccessor.java:72)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.sal.core.transaction.HostContextTransactionTemplate.execute(HostContextTransactionTemplate.java:18)
[INFO] [INFO] [talledLocalContainer] at sun.reflect.GeneratedMethodAccessor252.invoke(Unknown Source)
[INFO] [INFO] [talledLocalContainer] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[INFO] [INFO] [talledLocalContainer] at java.lang.reflect.Method.invoke(Method.java:498)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
[INFO] [INFO] [talledLocalContainer] at com.sun.proxy.$Proxy180.execute(Unknown Source)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:131)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.plugins.edgeindex.lucene.tasks.ReIndexPermissionsIndexTask.perform(ReIndexPermissionsIndexTask.java:60)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.plugins.edgeindex.job.EdgeIndexQueueFlusher.lambda$null$0(EdgeIndexQueueFlusher.java:35)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.fugue.Option$Some.foreach(Option.java:441)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.plugins.edgeindex.lucene.JournalEdgeIndexTaskQueue.lambda$processEntriesInternal$1(JournalEdgeIndexTaskQueue.java:97)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.impl.journal.DefaultJournalService.lambda$convert$0(DefaultJournalService.java:83)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.impl.journal.DefaultJournalManager.processEntries(DefaultJournalManager.java:81)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.impl.journal.JournalManager.processNewEntries(JournalManager.java:101)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.impl.journal.DefaultJournalService.processEntries(DefaultJournalService.java:40)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.api.service.journal.JournalService.processNewEntries(JournalService.java:100)
[INFO] [INFO] [talledLocalContainer] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[INFO] [INFO] [talledLocalContainer] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
[INFO] [INFO] [talledLocalContainer] at com.sun.proxy.$Proxy385.processNewEntries(Unknown Source)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.plugins.edgeindex.lucene.JournalEdgeIndexTaskQueue.processEntriesInternal(JournalEdgeIndexTaskQueue.java:93)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.plugins.edgeindex.lucene.JournalEdgeIndexTaskQueue.lambda$processEntries$0(JournalEdgeIndexTaskQueue.java:85)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.plugins.edgeindex.lucene.JournalEdgeIndexTaskQueue.processEntries(JournalEdgeIndexTaskQueue.java:82)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.plugins.edgeindex.job.EdgeIndexQueueFlusher.lambda$null$1(EdgeIndexQueueFlusher.java:33)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.bonnie.LuceneConnection.withWriter(LuceneConnection.java:491)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.plugins.edgeindex.job.EdgeIndexQueueFlusher.lambda$runJob$2(EdgeIndexQueueFlusher.java:33)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.bonnie.LuceneConnection.withBatchUpdate(LuceneConnection.java:524)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.plugins.edgeindex.job.EdgeIndexQueueFlusher.runJob(EdgeIndexQueueFlusher.java:33)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.impl.schedule.caesium.JobRunnerWrapper.doRunJob(JobRunnerWrapper.java:117)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.impl.schedule.caesium.JobRunnerWrapper.lambda$runJob$0(JobRunnerWrapper.java:87)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.confluence.impl.schedule.caesium.JobRunnerWrapper.runJob(JobRunnerWrapper.java:87)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.scheduler.core.JobLauncher.runJob(JobLauncher.java:134)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.scheduler.core.JobLauncher.launchAndBuildResponse(JobLauncher.java:106)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.scheduler.core.JobLauncher.launch(JobLauncher.java:90)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.launchJob(CaesiumSchedulerService.java:435)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.executeLocalJob(CaesiumSchedulerService.java:402)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.executeQueuedJob(CaesiumSchedulerService.java:380)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.scheduler.caesium.impl.SchedulerQueueWorker.executeJob(SchedulerQueueWorker.java:66)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.scheduler.caesium.impl.SchedulerQueueWorker.executeNextJob(SchedulerQueueWorker.java:60)
[INFO] [INFO] [talledLocalContainer] at com.atlassian.scheduler.caesium.impl.SchedulerQueueWorker.run(SchedulerQueueWorker.java:35)
[INFO] [INFO] [talledLocalContainer] at java.lang.Thread.run(Thread.java:748)
[INFO] [INFO] [talledLocalContainer] 2021-04-12 09:30:51,200 ERROR [main] [com.atlassian.threadlocal.BruteForceThreadLocalCleanup] logErr Thread[Caesium-1-2,5,Caesium-1] created a ThreadLocal with key of type [org.springframework.core.NamedThreadLocal] (value [Prototype beans currently in creation]) and a value of type [null] (value [null]). This will be cleaned up
[INFO] [INFO] [talledLocalContainer] 2021-04-12 09:30:51,202 ERROR [Caesium-1-2] [plugins.edgeindex.job.EdgeIndexQueueFlusher] lambda$null$0 Error performing index task: com.atlassian.confluence.plugins.edgeindex.lucene.tasks.ReIndexPermissionsIndexTask@692c29a2 ....
Tomcat fails to start which results in confluence attempts to start failing.
Any pointers as to how i might be able to resolve this?  I have also amended the confluence.data.version and tried to build but this hasnt made a difference.
Fabian Lim
Hi @Shinal Pala
If you are still having issues with this one, I suggest you post it on the dev community boards.
Good Luck.
SERVER
