Error when starting own confluence Dockerfile with alpine_java jdk
Moritz Münker
May 21, 2018
When i start the container i get the following error:
[FATAL tini (6)] exec /entrypoint.sh failed: Permission denied
Not sure what to do now?
gaurav June 1, 2018
I think you already sloved this problem .
But as like @Edwin Kyalangalilwa says. it is permission issue a conclusion.
chmod +x ~/<path-to-file>/entrypoint.sh
Build docker image again.
It will run
Edwin Kyalangalilwa
May 22, 2018
Hi @Moritz Münker,
Either the file entrypoint.sh is not an executable file or the user being used to run the container doesn't have access to run the file.
Check permissions and whether the file is executable.
atlassian, confluence, marketing templates, confluence templates, marketing project management, content strategy, campaign planning, marketing collaboration, confluence for marketers, atlassian learning, marketing workflows, confluence best practices
5 must-use templates for Marketing teams (from a Confluence Marketer!) 👩🏻‍🎨
Read more 📚
