Error while upgrading from Confluence Wiki 3.5.1 to 4.0.5
alok avjeet October 6, 2012
I am getting the below error in my atlassian-confluence.log :
2012-10-07 09:18:30,242 ERROR [main] [atlassian.confluence.upgrade.UpgradeLauncherServletContextListener] contextInitialized Upgrade failed, application will not start: Upgrade task com.atlassian.confluence.upgrade.upgradetask.LoginInfoUpgradeTask@225c8c05 failed during the UPGRADE phase due to: More than one row with the given identifier was found: BucketPropertySetItem[entityId=0,entityName=CWD_progers,key=confluence.user.last.login.date,type=7,boolean=false,string=<null>,text=<null>,int=0,double=0.0,long=0,date=2007-09-27 09:58:17.704], for class: bucket.user.propertyset.BucketPropertySetItem; nested exception is net.sf.hibernate.HibernateException: More than one row with the given identifier was found: BucketPropertySetItem[entityId=0,entityName=CWD_progers,key=confluence.user.last.login.date,type=7,boolean=false,string=<null>,text=<null>,int=0,double=0.0,long=0,date=2007-09-27 09:58:17.704], for class: bucket.user.propertyset.BucketPropertySetItem
com.atlassian.confluence.upgrade.UpgradeException: Upgrade task com.atlassian.confluence.upgrade.upgradetask.LoginInfoUpgradeTask@225c8c05 failed during the UPGRADE phase due to: More than one row with the given identifier was found: BucketPropertySetItem[entityId=0,entityName=CWD_progers,key=confluence.user.last.login.date,type=7,boolean=false,string=<null>,text=<null>,int=0,double=0.0,long=0,date=2007-09-27 09:58:17.704], for class: bucket.user.propertyset.BucketPropertySetItem; nested exception is net.sf.hibernate.HibernateException: More than one row with the given identifier was found: BucketPropertySetItem[entityId=0,entityName=CWD_progers,key=confluence.user.last.login.date,type=7,boolean=false,string=<null>,text=<null>,int=0,double=0.0,long=0,date=2007-09-27 09:58:17.704], for class: bucket.user.propertyset.BucketPropertySetItem
at com.atlassian.confluence.upgrade.AbstractUpgradeManager.executeUpgradeStep(AbstractUpgradeManager.java:212)
at com.atlassian.confluence.upgrade.AbstractUpgradeManager.runUpgradeTasks(AbstractUpgradeManager.java:148)
at com.atlassian.confluence.upgrade.AbstractUpgradeManager.upgrade(AbstractUpgradeManager.java:98)
at com.atlassian.confluence.upgrade.UpgradeLauncherServletContextListener.contextInitialized(UpgradeLauncherServletContextListener.java:45)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4205)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4704)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
at org.apache.catalina.core.StandardService.start(StandardService.java:525)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
Caused by: org.springframework.orm.hibernate.HibernateSystemException: More than one row with the given identifier was found: BucketPropertySetItem[entityId=0,entityName=CWD_progers,key=confluence.user.last.login.date,type=7,boolean=false,string=<null>,text=<null>,int=0,double=0.0,long=0,date=2007-09-27 09:58:17.704], for class: bucket.user.propertyset.BucketPropertySetItem; nested exception is net.sf.hibernate.HibernateException: More than one row with the given identifier was found: BucketPropertySetItem[entityId=0,entityName=CWD_progers,key=confluence.user.last.login.date,type=7,boolean=false,string=<null>,text=<null>,int=0,double=0.0,long=0,date=2007-09-27 09:58:17.704], for class: bucket.user.propertyset.BucketPropertySetItem
at org.springframework.orm.hibernate.SessionFactoryUtils.convertHibernateAccessException(SessionFactoryUtils.java:597)
at org.springframework.orm.hibernate.HibernateAccessor.convertHibernateAccessException(HibernateAccessor.java:353)
at org.springframework.orm.hibernate.HibernateTemplate.execute(HibernateTemplate.java:375)
at org.springframework.orm.hibernate.HibernateTemplate.execute(HibernateTemplate.java:337)
at bucket.user.persistence.dao.hibernate.BucketPropertySetDAO.findByKey(BucketPropertySetDAO.java:92)
at sun.reflect.GeneratedMethodAccessor72.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:106)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy65.findByKey(Unknown Source)
at bucket.user.propertyset.BucketPropertySet.getByKey(BucketPropertySet.java:209)
at bucket.user.propertyset.BucketPropertySet.get(BucketPropertySet.java:168)
at com.opensymphony.module.propertyset.AbstractPropertySet.getDate(AbstractPropertySet.java:258)
at com.atlassian.crowd.embedded.propertyset.DebugLoggingPropertySet.getDate(DebugLoggingPropertySet.java:89)
at com.atlassian.user.impl.cache.properties.CachedPropertySet.getDate(CachedPropertySet.java:221)
at com.atlassian.user.impl.cache.properties.CachingPropertySetFactory$RecacheOnWritePropertySet.getDate(CachingPropertySetFactory.java:132)
at com.atlassian.confluence.upgrade.upgradetask.LoginInfoUpgradeTask$1.apply(LoginInfoUpgradeTask.java:91)
at com.atlassian.confluence.upgrade.upgradetask.LoginInfoUpgradeTask$1.apply(LoginInfoUpgradeTask.java:78)
at com.atlassian.confluence.core.persistence.hibernate.HibernateSessionManager$1.doInTransaction(HibernateSessionManager.java:110)
at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:128)
at com.atlassian.confluence.core.persistence.hibernate.HibernateSessionManager.executeWithSessionClearing(HibernateSessionManager.java:105)
at com.atlassian.confluence.upgrade.upgradetask.LoginInfoUpgradeTask.doUpgrade(LoginInfoUpgradeTask.java:67)
at $Proxy33.doUpgrade(Unknown Source)
at com.atlassian.confluence.upgrade.AbstractUpgradeManager$UpgradeStep$4.execute(AbstractUpgradeManager.java:492)
at com.atlassian.confluence.upgrade.AbstractUpgradeManager.executeUpgradeStep(AbstractUpgradeManager.java:188)
... 18 more
Caused by: net.sf.hibernate.HibernateException: More than one row with the given identifier was found: BucketPropertySetItem[entityId=0,entityName=CWD_progers,key=confluence.user.last.login.date,type=7,boolean=false,string=<null>,text=<null>,int=0,double=0.0,long=0,date=2007-09-27 09:58:17.704], for class: bucket.user.propertyset.BucketPropertySetItem
at net.sf.hibernate.loader.EntityLoader.load(EntityLoader.java:71)
at net.sf.hibernate.loader.EntityLoader.load(EntityLoader.java:51)
at net.sf.hibernate.persister.EntityPersister.load(EntityPersister.java:413)
at net.sf.hibernate.impl.SessionImpl.doLoad(SessionImpl.java:2129)
at net.sf.hibernate.impl.SessionImpl.doLoadByClass(SessionImpl.java:1999)
at net.sf.hibernate.impl.SessionImpl.get(SessionImpl.java:1935)
at sun.reflect.GeneratedMethodAccessor73.invoke(Unknown Source)
at org.springframework.orm.hibernate.HibernateTemplate$CloseSuppressingInvocationHandler.invoke(HibernateTemplate.java:1123)
at $Proxy99.get(Unknown Source)
at bucket.user.persistence.dao.hibernate.BucketPropertySetDAO$2.doInHibernate(BucketPropertySetDAO.java:98)
at org.springframework.orm.hibernate.HibernateTemplate.execute(HibernateTemplate.java:370)
... 55 more
2012-10-07 09:18:30,249 ERROR [main] [atlassian.confluence.upgrade.UpgradeLauncherServletContextListener] contextInitialized 1 errors were encountered during upgrade:
2012-10-07 09:18:30,249 ERROR [main] [atlassian.confluence.upgrade.UpgradeLauncherServletContextListener] contextInitialized 1: More than one row with the given identifier was found: BucketPropertySetItem[entityId=0,entityName=CWD_progers,key=confluence.user.last.login.date,type=7,boolean=false,string=<null>,text=<null>,int=0,double=0.0,long=0,date=2007-09-27 09:58:17.704], for class: bucket.user.propertyset.BucketPropertySetItem; nested exception is net.sf.hibernate.HibernateException: More than one row with the given identifier was found: BucketPropertySetItem[entityId=0,entityName=CWD_progers,key=confluence.user.last.login.date,type=7,boolean=false,string=<null>,text=<null>,int=0,double=0.0,long=0,date=2007-09-27 09:58:17.704], for class: bucket.user.propertyset.BucketPropertySetItem
2012-10-07 09:18:30,250 WARN [main] [atlassian.confluence.plugin.PluginFrameworkContextListener] contextInitialized Not starting full plugin system due to upgrade or licensing errors
2012-10-07 09:18:33,414 INFO [main] [com.atlassian.confluence.lifecycle] init Confluence is ready to serve
I tried to resolve this error but could not. Please guide me to resolve this issue. I got the same error when I tried to upgrade to 4.3.
alok
GuilhermeA
October 8, 2012
Hello Alok!
I've seen this before. Usually this happens when you run the upgrade task twice.
The error above is complaining about a user already in a table:
application will not start: Upgrade task com.atlassian.confluence.upgrade.upgradetask.LoginInfoUpgradeTask@225c8c05 failed during the UPGRADE phase due to: More than one row with the given identifier was found: BucketPropertySetItem[entityId=0,entityName=CWD_progers,key=confluence.user.last.login.date,type=7,boolean=false,string=&lt;null&gt;,text=&lt;null&gt;,int=0,double=0.0,long=0,date=2007-09-27 09:58:17.704], for class: bucket.user.propertyset.BucketPropertySetItem; nested exception is net.sf.hibernate.HibernateException
I would suggest rolling back to a previous state of this upgrade, and double checking if this version has not been upgraded.
In another scearnio we could try to delete the affected rows:
delete from logininfo;
This will clean the affected Row which the upgrade is complaining. But please before proceeding backup, and if you encounter any problems revert it again.
Guilherme
alok avjeet October 9, 2012
Hi Guilherme,
Thank you for your inputs.
Yes you are correct that it is upgraded twice but that is my need. I upgraded this instance from 2.10 to 3.5.13. Now I am upgrading it to 4.3. This is where I am getting this error. Can't I upgrade a confluence instance twice? How do I do that?
I do not see any table called logininfo in my db.
Thanks & Regards,
Alok
