Error with Gliffy and Recommended Mails from Confluence 4.2
Dirk Bromberg
May 2, 2012
after upgrade to confluence 4.2 we get the recommended mails... it is fine but has one bug.
Pages with Gliffy Images on are rendered in the mail as:
Error rendering macro 'gliffy' : java.lang.ClassCastException: com.atlassian.confluence.util.ConfluenceMockServletRequest cannot be cast to javax.servlet.http.HttpServletRequest
Is there a bug in confluence or in gliffy?
Is there a solution out somewhere?
Keith Rockhold
May 3, 2012
Hi Dirk,
Thanks for opening that support ticket, but we found the bug in Gliffy that was causing it. You, and anyone else who suffers from this problem, should install the latest Gliffy version (4.2.3) to resolve this issue. You can get it from the link below, or from the Confluence UPM:
http://www.gliffy.com/products/confluence-plugin/download/archive/gliffy-confluence-plugin-4.2.3.jar
Thank you,
Keith Rockhold
Support Engineer
keith@gliffy.com
Gliffy Inc.
PO Box 7775 #35255
San Francisco, CA, 94120-7775
877-2-Gliffy (877-245-4339)
Keith Rockhold
May 2, 2012
Hi Dirk,
Would you please open a support ticket at http://support.gliffy.com. I'd like to ask for information we shouldn't share in an open venue. However, I do believe this issue will be quickly solved.
Thank you,
Keith Rockhold
Support Engineer
keith@gliffy.com
Gliffy Inc.
PO Box 7775 #35255
