Error with ScriptRunner Custom Macro example
Dave Hollinden
I'm attempting to create a ScriptRunner custom script macro by following the example at:
https://scriptrunner.adaptavist.com/latest/confluence/macros/CustomMacros.html#_cql_search_macro
When I enter the macro code from the example, I get the following errors:
I'm on Confluence 6.0.6 and using ScriptRunner 4.3.17.
I'm a newbie, so any help would be very much appreciated.
Dave
JohnsonHoward
April 25, 2017
Hi Dave,
Can I see which classes you are importing please?
Johnson
Dave Hollinden
Hi Johnson,
I copied the entire script from the example at the link in my original post pasted it into my script macro, as follows:
import com.atlassian.confluence.api.model.Expansion
import com.atlassian.confluence.api.model.content.Content
import com.atlassian.confluence.api.model.pagination.PageResponse
import com.atlassian.confluence.api.model.pagination.SimplePageRequest
import com.atlassian.confluence.api.model.search.SearchContext
import com.atlassian.confluence.api.service.search.CQLSearchService
import com.atlassian.confluence.xhtml.api.XhtmlContent
import com.onresolve.scriptrunner.runner.ScriptRunnerImpl
import groovy.xml.MarkupBuilder
def cqlSearchService = ScriptRunnerImpl.getOsgiService(CQLSearchService)
def xhtmlContent = ScriptRunnerImpl.getOsgiService(XhtmlContent)
def maxResults = parameters.maxResults as Integer ?: 10
def cqlQuery = parameters.cql as String
def pageRequest = new SimplePageRequest(0, maxResults)
def searchResult = cqlSearchService.searchContent(cqlQuery, SearchContext.builder().build(), pageRequest, Expansion.combine("space")) as PageResponse<Content>
def writer = new StringWriter()
def builder = new MarkupBuilder(writer)
if (searchResult.size()) {
builder.table {
tbody {
tr {
th { p("Title") }
th { p("Space") }
searchResult.results.each { content ->
tr {
td {
p {
"ac:link" {
"ri:page"("ri:content-title": content.title, "ri:space-key": content.space.key)
td { p(content.space.name) }
if (searchResult.respondsTo("totalSize")) { // confl 5.8+
builder.p("Showing ${Math.min(maxResults, searchResult.totalSize())} of ${searchResult.totalSize()}")
else {
builder.p("No results")
def view = xhtmlContent.convertStorageToView(writer.toString(), context)
view
Thanks for your help.
Dave
