Errors when starting Confluence after MySQL to MS SQL Server conversion
Michael Johnston April 14, 2022
Using Microsoft's SQL Server Migration Assistant for MySQL, I've run a successful import but when starting Confluence getting the error below:
Cause
com.atlassian.activeobjects.internal.ActiveObjectsInitException: bundle [com.atlassian.plugins.authentication.atlassian-authentication-plugin]
    at com.atlassian.activeobjects.osgi.TenantAwareActiveObjects$1$1$1.call(TenantAwareActiveObjects.java:95)
caused by: java.lang.IllegalStateException: TABLE: AO_ED669C_IDP_CONFIG: ADDITIONAL_JIT_SCOPES - ADDITIONAL_SCOPES - AUTHORIZATION_ENDPOINT - BUTTON_TEXT - CLIENT_ID - CLIENT_SECRET - ENABLED - ENABLE_REMEMBER_ME - ID - INCLUDE_CUSTOMER_LOGINS - ISSUER - LAST_UPDATED - MAPPING_DISPLAYNAME - MAPPING_EMAIL - MAPPING_GROUPS - NAME - SAML_IDP_TYPE - SIGNING_CERT - SSO_TYPE - SSO_URL - TOKEN_ENDPOINT - USERNAME_ATTRIBUTE - USERNAME_CLAIM - USER_INFO_ENDPOINT - USER_PROVISIONING_ENABLED - USE_DISCOVERY - can't find type 5 (precision=5) in field ENABLED
    at net.java.ao.schema.helper.DatabaseMetaDataReaderImpl.getFields(DatabaseMetaDataReaderImpl.java:104)
Stack Trace:[hide]
	at com.atlassian.activeobjects.osgi.TenantAwareActiveObjects$1$1$1.call(TenantAwareActiveObjects.java:86)
	at com.atlassian.sal.core.executor.ThreadLocalDelegateCallable.call(ThreadLocalDelegateCallable.java:38)
	at com.atlassian.confluence.impl.vcache.VCacheRequestContextManager.doInRequestContextInternal(VCacheRequestContextManager.java:84)
	at com.atlassian.confluence.impl.vcache.VCacheRequestContextManager.doInRequestContext(VCacheRequestContextManager.java:68)
	at com.atlassian.confluence.vcache.VCacheRequestContextOperations.lambda$withRequestContext$1(VCacheRequestContextOperations.java:59)
	at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.base/java.lang.Thread.run(Unknown Source)
Caused by: java.lang.IllegalStateException: TABLE: AO_ED669C_IDP_CONFIG: ADDITIONAL_JIT_SCOPES - ADDITIONAL_SCOPES - AUTHORIZATION_ENDPOINT - BUTTON_TEXT - CLIENT_ID - CLIENT_SECRET - ENABLED - ENABLE_REMEMBER_ME - ID - INCLUDE_CUSTOMER_LOGINS - ISSUER - LAST_UPDATED - MAPPING_DISPLAYNAME - MAPPING_EMAIL - MAPPING_GROUPS - NAME - SAML_IDP_TYPE - SIGNING_CERT - SSO_TYPE - SSO_URL - TOKEN_ENDPOINT - USERNAME_ATTRIBUTE - USERNAME_CLAIM - USER_INFO_ENDPOINT - USER_PROVISIONING_ENABLED - USE_DISCOVERY - can't find type 5 (precision=5) in field ENABLED
	at net.java.ao.schema.ddl.SchemaReader.readFields(SchemaReader.java:126)
	at net.java.ao.schema.ddl.SchemaReader.readTable(SchemaReader.java:110)
	at net.java.ao.schema.ddl.SchemaReader.access$000(SchemaReader.java:62)
	at net.java.ao.schema.ddl.SchemaReader$1.apply(SchemaReader.java:99)
	at net.java.ao.schema.ddl.SchemaReader$1.apply(SchemaReader.java:97)
	at com.google.common.collect.Iterators$6.transform(Iterators.java:785)
	at com.google.common.collect.TransformedIterator.next(TransformedIterator.java:47)
	at com.google.common.collect.Iterators.addAll(Iterators.java:358)
	at com.google.common.collect.Lists.newArrayList(Lists.java:147)
	at com.google.common.collect.Lists.newArrayList(Lists.java:133)
	at net.java.ao.schema.ddl.SchemaReader.readSchema(SchemaReader.java:97)
	at net.java.ao.schema.ddl.SchemaReader.readSchema(SchemaReader.java:88)
	at net.java.ao.schema.ddl.SchemaReader.readSchema(SchemaReader.java:81)
	at net.java.ao.schema.SchemaGenerator.generateImpl(SchemaGenerator.java:107)
	at net.java.ao.schema.SchemaGenerator.migrate(SchemaGenerator.java:84)
	at net.java.ao.EntityManager.migrate(EntityManager.java:131)
	at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.migrate(EntityManagedActiveObjects.java:52)
	at com.atlassian.activeobjects.internal.AbstractActiveObjectsFactory.lambda$create$0(AbstractActiveObjectsFactory.java:73)
	at com.atlassian.sal.core.transaction.HostContextTransactionTemplate$1.doInTransaction(HostContextTransactionTemplate.java:21)
	at com.atlassian.sal.spring.component.SpringHostContextAccessor.lambda$doInTransaction$0(SpringHostContextAccessor.java:70)
	at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:140)
	at com.atlassian.sal.spring.component.SpringHostContextAccessor.doInTransaction(SpringHostContextAccessor.java:68)
	at com.atlassian.confluence.spring.transaction.interceptor.ConfluenceSpringHostContextAccessor.access$001(ConfluenceSpringHostContextAccessor.java:21)
	at com.atlassian.confluence.spring.transaction.interceptor.ConfluenceSpringHostContextAccessor.lambda$doInTransaction$3(ConfluenceSpringHostContextAccessor.java:72)
	at com.atlassian.confluence.spring.transaction.interceptor.ConfluenceSpringHostContextAccessor.doInTransaction(ConfluenceSpringHostContextAccessor.java:72)
	at com.atlassian.sal.core.transaction.HostContextTransactionTemplate.execute(HostContextTransactionTemplate.java:18)
	at jdk.internal.reflect.GeneratedMethodAccessor293.invoke(Unknown Source)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.base/java.lang.reflect.Method.invoke(Unknown Source)
	at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
	at com.sun.proxy.$Proxy272.execute(Unknown Source)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:343)
	at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
	at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:136)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:124)
	at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70)
	at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
	at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
	at com.sun.proxy.$Proxy1086.execute(Unknown Source)
	at com.atlassian.activeobjects.internal.AbstractActiveObjectsFactory.create(AbstractActiveObjectsFactory.java:70)
	at com.atlassian.activeobjects.internal.DelegatingActiveObjectsFactory.create(DelegatingActiveObjectsFactory.java:32)
	at com.atlassian.activeobjects.osgi.TenantAwareActiveObjects$1$1$1.call(TenantAwareActiveObjects.java:91)
	... 9 more
Does anyone else have experience migrating from a MySQL DB to MS SQL Server? I've got an open ticket with Atlassian Support. That ticket identified at least one column that is not the right datatype.
Nic Brough -Adaptavist-
April 14, 2022
I've found the MS migration assistant to be mostly useless (and not just for Atlassian stuff).  The only method that works reliably for Jira or Confluence is to use their native export/import tools.
atlassian, confluence, marketing templates, confluence templates, marketing project management, content strategy, campaign planning, marketing collaboration, confluence for marketers, atlassian learning, marketing workflows, confluence best practices
5 must-use templates for Marketing teams (from a Confluence Marketer!) 👩🏻‍🎨
Read more 📚
