×Hi all
I just used the Excel Macro.
However it displays the dates in the spreadsheet in USA format, however I am in Australia and would like dates to be displayed as dd/mm/yy format.
The spreadsheet has the dates formated as dd/mm/yy - but it's not displayed that way in confluence.
Is there a way to fix this?
Thanking you in anticipation.
There is no workaround for this. However, you can vote for this feature: https://jira.atlassian.com/browse/CONFSERVER-59312
Regards
Hi @Debbie Charles 👋
I've taken a quick look at this for you and it appears it is a common issue over the years for users. As mentioned by @Fabian Lim, I'd recommend voting for this ticket and watching for any further updates: https://jira.atlassian.com/browse/CONFSERVER-59312
I hope this helps but if you have any questions just ask away 😃
All the best,
Laura
@Debbie Charles Date and time formats can be adjusted in the Settings under General Configuration -> Formatting and International Settings. That should change them throughout the system when you post dates.
Can you point me where I can find this option in Confluence?
