Expand menu macro does not function inside a tabs page.
ElizabethC
I created my Tabs container  macro> tabs page macro > Expand macro which has 3 items listed.
This macro works everywhere I have used it, so far, but inside a tabs page, the arrow does not expose the 3 child menu items.
Is this a broken behavior or just not supported? Thanks.
Jonathan Smith
March 26, 2019 edited
Hi @ElizabethC ,
  How are you making your tabs container? Is this an add-on? Expand macro comes with Confluence but I don't see a tabs.
Another option is to have your admin download the free app Refined Toolkit for Confluence from RefinedWiki.  This came with UI Tabs and UI Expand. These work well together.
ElizabethC
 In my confluence there is Tabs Container, then inside that you put tabs pages macros, and they become the tabs.
In this tabs page I am trying to use an expand menu.
This is what I was doing.
ElizabethC
I see I can "request" but as I am not our main space's administrator, (I just have admin rights to child pages) I am not sure how you go about adding this macro to what I see when I do the "Other Macros" option.
ElizabethC
Oh wait I see what happens the site admin gets the request.
Jonathan Smith
March 27, 2019
@ElizabethC ,
  The tabs page / tabs container is more than likely an installed macro. You can always ask your admin to open a case with that vendor to address your expand situation.
Also, based on the macro naming, your tabs page should be on the outside with tabs containers on the inside. Give this layout a shot:
Tabs Page
--- Tabs Container
--- --- expand
--- --- expand
--- Tabs Container
--- --- expand
--- --- expand
Again, I don't have this macro, but it sounds like your content (expand macros) would live in the "container".
- Jonathan
Jonathan Smith
March 28, 2019
@ElizabethC Interested to know if switching tabs page and container fixed your situation.
- Jonathan
Jonathan Smith
March 28, 2019
@ElizabethC ,
  I updated the first post. The UI Tabs and UI Expand is from a different vendor. This add-on is free!
- Jonathan
Jacob Meler
June 5, 2019
I ran into the same issue, looks like the same vendors as the OP.  It works in the preview, but not when saved.
Switching the containers and pages layout very much did not work.
Sean Dooley
March 23, 2020
Try turning off lazy loading.
Tracey Coleman
February 18, 2021
I had the same problem ... turning off lazy loading worked, thanks!
Like Sean Dooley likes this
Jenny Bennion
March 16, 2022
This worked for me as well.  Thanks!
James Park
I do not think Expand can contain tabs by design. I think it should though.
atlassian, confluence, marketing templates, confluence templates, marketing project management, content strategy, campaign planning, marketing collaboration, confluence for marketers, atlassian learning, marketing workflows, confluence best practices
5 must-use templates for Marketing teams (from a Confluence Marketer!) 👩🏻‍🎨
Read more 📚
