×Link to result document: https://www.dropbox.com/s/v0599jkrtsds2or/confluence%20export.pdf?dl=0
I assume your default font does not support cyrillic characters, which is why they're missing in the export.
Have you tried using a different font (e.g. Arial Unicode), which supports all needed characters?
Nils
Hi, I thought confluence has to do it without any configurations.
I installed another font in configuration panel, and all become fine.
Thank you.
Can please some point me how to change that font? Is it in Space configuration or in global Confluence instance config?
My default font does support cyrillic characters but not sure if cloud installed fonts are. Without success tried to use CSS styles as described here https://confluence.atlassian.com/conf76/advanced-pdf-export-customizations-1018768533.html
My style is
@font-face {
src: url(https://fonts.googleapis.com/css?family=Tangerine);
-fs-pdf-font-embed: embed;
Any ideas and help appreciated. Thank you!
How install font for export in other languages:
https://confluence.atlassian.com/doc/create-a-pdf-in-another-language-175473.html
I did and solved problem
