Export to static HTML or to Help (similar to WebHelp)
Rakefet Zur
October 13, 2014
We are evaluating Confluence. We need to generate help for applications from Confluence. It can be static html pages but they must have a TOC and breadcrumbs.
The built-in export to HTML provides standalone html files with no TOC. We are also testing scroll html export but are having difficulties there as well.
Are there any other plugins or options to generate some sort of html help from Confluence?
(If the option is to export to Word and then use RoboHelp - we won't move to Confluence...).
Rakefet
Jens Rutschmann _K15t_
September 9, 2015
while this answer is a bit late, I'd like to refer you to the new version 3.3 of Scroll HTML Exporter that provides HTML exports with TOC and full text search feature.
See https://www.k15t.com/display/HTML/Scroll+HTML+Exporter+3.3+Release+Notes
Jens
Paul LaBarbera
Curious if you've made any progress here. I'd like to know some tricks as well
Justin Justin
atlassian, confluence, marketing templates, confluence templates, marketing project management, content strategy, campaign planning, marketing collaboration, confluence for marketers, atlassian learning, marketing workflows, confluence best practices
5 must-use templates for Marketing teams (from a Confluence Marketer!) 👩🏻‍🎨
Read more 📚
