Exporting Question
Karl Street
October 23, 2023
Hi all,
I have a (hopefully) quick question. If you have a Published Confluence page but also have a draft or signoff version of the same page and you export it is it always going to be the published page that’s exported?
I have tested this and it seems to be the case but a user is saying they expects whatever the version they are on is the one that should be exported.
Karl
Barbara Szczesniak
October 24, 2023
@Karl Street Welcome to the Atlassian Community!
Are you saying that you have a page that:
  1. You have published (at least once)
  2. You have then edited the page, but not published the changes.
When you say export, do you mean that you are trying to export the page to a PDF or Word?
If this is the case, I don't think you can publish the draft, since the Export command is only available in View mode, which doesn't show the unpublished changes.
