×I am tasked with making sure all requested changes to documents have actually been properly addressed.
We have many documents in Confluence, some of them at version 175 and higher. Our SMEs have been highlighting text and making comments to the documents, and the persons reading the comments have been deleting the text and making changes. Of course, when the text is deleted the comment goes away. Now, I am coming along behind, trying to make sure the original comments were properly addressed. How can I access those original comments? Is there a way?
Thanks in advance!
Based on my testing in Confluence 6.6.1 (server), resolved and unresolved comments will still display on a page after you delete the sentence with the comment.
You can review these by clicking ... (page properties), and then click resolved comments.
Even if the comment wasn't answered, they will still display in "resolved comments".
When I go to a previous version of a document and follow the process you describe, it only shows comments I made concerning other documents associated with this one, and nobody else's. Help!
What displays in the current version? Should have all prior comments/answers.
For future proofing, you might want to look into Camala Workflows and create an approval / publishing workflow. Changes requested --- changes made --- changes approved --- publish.. etc.
I am looking at a document right now, it is on version 214. The Resolved Comments entry in the ... menu shows 8 comments. I personally made over 30 comments in a previous version of this document.
I need to know how to look at all of the comments from all previous versions...
Is it possible your comments were part of replies? These are also visible at the bottom of each resolved comment.
If not replies, I would suggest creating a test page and seeing how comments are working in your environment. All of mine (including restoring version 1 as a test) saved all comment/reply tests:
If this functionality isn't working correctly, you should open a ticket with Atlassian.
Hi Guys, do you know if there is way to display the resolved comments on a page? With a macro or so?
Also is there a way to view resolved comments other than through the '... > resolved comments' option?
We have a client who can't view it due to their browser limitations and can't change the browsers so I'm looking for alternative ways of viewing this information.
Thanks.
what browser and what version of the browser is it?
Where do I find the resolved comments? They disappeared.
Hi Mike @Magic Mike ,
Talk Advanced Inline Comments for Confluence may come in handy for you. The app provides a feature called the Talk report where you can see not only the resolved comments but also the archived and open ones. Along with this, you find the following information in the report:
You can create a report for any page and/or space without leaving your current page.
The report is compatible with Table Filter and Charts app. You can use it to add filters to your reports, create pivot tables and charts to summarize and visualize the report data.
I hope I've managed to help you.
Iryna
Wow this bug is serious I have just wasted so much time on this. My comments are just being marked as resolved even saying text is deleted even though the text I've made the comments is clearly still there.
