Float panel
Jack Bates June 18, 2014
How do I make a Confluence panel float? (Similarly to CSS float:left or float: right)
David at David Simpson Apps
June 19, 2014 edited
You'll need to wrap it in a user macro which does the floating.
For example something like this:
## @noparams
<div style="width:30%;float:left;">$body</div>
Deleted user November 15, 2015
Thank you!
allie ruby January 14, 2021
What is a user macro? What exact Macro do you recommend?
A user macro is something that's available on Confluence Server and Data Center only. If you're on Cloud, they don't exist.
