Sign up Log in
Floating TOC in the right column
Corti Corti July 8, 2016
Hi all,
I have a page with a two columns layout and I put a TOC on the right one. I would like to have the TOC always visible even though when I do scroll down. Is there any nice macro solution for this?
I get some results via CSS, setting a name for the div of the TOC and adding some CSS code like
.fixedPosition {
    max-width:370px;
    margin0 auto;
    positionfixed;
     top: 200px
any better option?
Many thanks.
J
2 accepted
3 votes
Michelle Rau HP
March 22, 2018
Thanks for this! I got decent results via CSS like this. It's a simple, half-transparent light gray box with a thin blue border that stays visible at the top right of the screen.
.toc-btf {
    float: right;
    position: fixed;
    width: 300px;
    right: 0px;
    top: 170px;
    background: rgba(229, 232, 232, 0.5);
    border: 1px solid #0096d6;
    padding: 5px;
This worked best when I put the TOC with the toc-btf class as the very first thing on the page.
The only annoyance is that other Confluence macros / page parts overlap the TOC in a distracting way. This is minor, but I would rather have the Note's yellow box be under, not over the TOC. If there is an adjustment I can make to CSS please tell me.
I'm a space admin, not a Confluence admin, so my options are limited. I did see the linked solutions above but they're not an option for me.
Zdeněk Šedivý July 10, 2018
I have a solution for your problem. Just move the macro with CSS style to the end of the page so that all the other macros used on the page are above CSS style. See picture. :)
Like 2 people like this
Michelle Rau HP
July 10, 2018
That worked! Thank you!
Krishnanand Nayak October 15, 2018
This solution worked for us.
Milo Test
July 8, 2016
@Davin Studer has your solution:
https://answers.atlassian.com/questions/285311
6 votes
wld-PKumbhare
July 19, 2018 edited
I got the TOC to float/sticky, thanks to the wonderful suggestions in this thread, but it only works in the preview mode, when I publish the page the TOC loses it's floating/sticky property. Has anyone faced this issue or am I missing something?
Mike MacDonald August 23, 2018
I am having this same issue. Has something changed due to an Atlassian update?
Kem McFadden
September 19, 2018
Same issue here. Works in Preview but not in Published mode.
Dan Towler
July 14, 2019
Yep - exactly the same issue here - using the Cloud version.
Ie. sticks perfectly in PREVIEW but scrolls once Published.
Has anyone found a fix to this one?
4 votes
hmohapatra
June 8, 2018 edited
I use this css in a two column page layout, for a floating scrollable TOC on the right side.The two column page does not let the content overlap with TOC.
Screenshot:Screen Shot 2018-06-08 at 11.20.15 PM.png
CSS:
.rightFloat {
position: fixed;
height: 600px;
overflow: auto;
top: 100px;
Michelle Rau HP
June 8, 2018
I'll try that out. Thanks much!
Zdeněk Šedivý June 22, 2018
What is the macro that you've got the ccs stylesheet on the page?
In Other Macros, there is no such thing.
Thank you.
hmohapatra
June 22, 2018
Name of the macro is CSS Stylesheet.
Zdeněk Šedivý June 24, 2018
I disagree because there is no such thread on marketplace.atlassian.com. :(
https://marketplace.atlassian.com/search?query=CSS+StylesSheet
Damien Tan
August 27, 2018
The CSS Stylesheet and div macros in the screenshot above is likely come together with the Content Formatting for Confluence plugin from Adaptavist
Like Max Foerster - K15t likes this
Dan Towler
July 12, 2019
Gday team.
I see that this solution, to fix a TOC in place despite scrolling, has been defined using the option:
position: fixed;
I'm using the Cloud-based Confluence and this control seems to have no effect.  I can confirm that all other controls within work. Ie. the TOC is correctly placed on the page, the shading, height and width all effective, but the TOC still scrolls off the page - despite using a FIXED position.
I'd be very grateful to any wiz who can tell me what I'm missing - to make this work.
Lam Ton December 8, 2019
Thanks, it works for me!
Xfr Dev
August 18, 2021
Fyi,
I've just created a user style with the css you have provided : https://userstyles.org/styles/205823/confluence-floating-toc
Sidhartha Kumar Sharma
May 15, 2021
Thanks for the great suggestions in this thread.
Is there a way to ensure that the floating ToC do not float over the footer section or the comments section? When it sticks beyond the actual content layout, it overlaps with the comments posted on the specific page.
Michael Yang - Shinetech Software
The floating table of content free plugin has just been released: https://marketplace.atlassian.com/1221271
Puvaneswary S
March 17, 2021
This is only for Server and data Center not Cloud
Anh Nguyen May 2, 2021
Great.  Thanks,
ncline-va
May 11, 2022
Would be great to make it available for Cloud :)
@Puvaneswary S @ncline-va The cloud version is available now!
Upcoming Confluence Events
