Forms and Confluence 4.2
Bill_Campbell
Hello - I need to create forms within the confluence. I started with the scaffolding plugin, which was great until 4.0 came out and it no longer works in a way I find is adequate. I
I can create templates, but want people to be able to fill in forms such as a customer profile sheet, derived from the template. I can't find a clean method on how to do this. Any idea?
Anyone creating forms that are user friendly where they can just input fields?
Alex Medved _ConfiForms_
Old question, but would like to mention that in 2015 there is an option to do this easily and fully integrated into Confluence, check out ConfiForms plugin for Confluence to create data entry forms and workflows (works on 5.1-5.8.x), but if needed could be run on Confluence 4.3+
Amalia
July 25, 2012
Bill_Campbell
Thank you - the concept of wufo is nice, but its not really integrated into confluence. I need the data to be in the WIKI not stored offsite. Neat product though.
Colin Goudie
July 25, 2012
Maybe check out freevo forms.
You could also just embed Wufoo forms if that works for you.
Bill_Campbell
Thanks - Freevo looks like the cat's meow, but it also has a $40,000 price tag (from what I could determine). Far too expensive for me to implement.
