Hello everybody,
we designed in Confluence a kind of a Project Overview Table, where every Project is listed with different information like Potential of turnover etc....
At the moment I'm trying to get this table into a BI tool. The problem is, that if I am using the odbc connector, the tables is store in the Confluence-DB as html content (logically), so I can not use it for Reporting etc.
When I'm trying to get the connection via the web-file integration, the table is not recognized from the BI tool.
(I'm using the Source-Link of the Confluence Table, where the Project table is...)
Anyway, if I am using the simple Excel "from Web-File" integration, it works.
As you can suerly guess, this is not a very "perfect" solution...
So my question is, is there a tool which can export exactly the table?
I allready read the documention of the Confluence CLI (Bobswift) but I'm not quite shure if it'll work that way.
Otherwise maybe it is possible with a simple ODBC connection?
Has anybody experience with this kind of use case ? ![]()
Thank you so much!
Greets Alex
Table Filter has a Pivot Table macro that provides basic BI tools. Also there is a Chart from Table macro that can help you to visualize results.
Hope it will help you.
I don't think the Confluence CLI will help. It can provide the page html or page source xhtml, but you still need a script or something to transform that into another form.
