Getting Jira Release notes into Confluence without Cutting and Pasting?
AER IT Procurement November 19, 2019
I have a JIRA project, once in, I navigate to the Releases, I then go to the version,  then click 'Release Notes' at the top of the screen.
Once there, there is an option to:
Edit/Copy Release Notes
The text area below allows the project release notes to be edited and copied to another document.
Is there any way to use the Jira Filter plugin to put the release notes into Confluence with out doing a manual cut and paste?
What would be the jql I would use?  Search on the version name?
Share the syntax please?
OR
Is there a better way?
Victor
Shannon S
November 21, 2019
Hello Victor,
Thank you for contacting us regarding this.
I believe you can achieve this in the Jira Issues Macro if you:
  1. Set the fixVersion
  2. Order by issuetype
  3. Display the Release Notes field.
Can you try that and let me know how it goes? We also have a template you can use, called Change Log, which will help you to create release notes pages.
See Create a Change Log for more details.
Let me know if you have any questions about that.
Shannon
Svein Inge Andersen
September 29, 2020
Ho do you make a Release Note field available?
Like # people like this
Christian Lopez Barron September 26, 2021
Same question
Like JR Kirkwood likes this
Amelia Earhart
How do you make a Release Note field available?
Sujeet Pathak
Hi @AER IT Procurement, this is Sujeet from Amoeboids. We have an app in the Atlassian marketplace that can serve your use case - Automated release notes for Jira.
Here you can generate release notes in confluence and even other different formats such as Email, PDF, Slack, PowerPoint, etc., and automate their delivery to relevant stakeholders through rule Automation.
If you are on the cloud, we even have a free version of this app to get you started quickly.
Do check out and reach out here if you need any further information.
Sujeet
