Since we started using Cucumber for various projects, we felt the need for a nice representation of Gherkin code within Confluence.
So I created a custom gherkin brush file based on the SyntaxHighlighter manual and added it to the Code Macro:
SyntaxHighlighter.brushes.Custom = function()
this.regexList = [
{ regex: SyntaxHighlighter.regexLib.singleLinePerlComments, css: 'comments' }, // #comments
{ regex: /(['\"]{3})([^\1])*?\1/gm, css: 'string' }, // multi-line strings like in python with """
{ regex: SyntaxHighlighter.regexLib.doubleQuotedString, css: 'string' }, // strings
{ regex: SyntaxHighlighter.regexLib.singleQuotedString, css: 'string' }, // strings
{ regex: /@.*$/gmi, css: 'color1' }, // @tags
{ regex: /^\s*(But |And |Then |When |Given |Scenarios|Examples|Scenario Template|Scenario Outline|Scenario|Background|Feature)/gmi, css: 'keyword' } // english
SyntaxHighlighter.brushes.Custom.aliases = ['gherkin'];
SyntaxHighlighter.brushes.Custom.prototype = new SyntaxHighlighter.Highlighter();
It currently looks ok but I wonder if someone from the community uses a similar/ better solution for that.
Feel free to use this, btw: gist
How to implement this JS in Jira ?
You're right @Ben Erridge, this one looks even better. I've updated the gist.
Thank you!
Hi @Andreas ,
Since you extensively use Cucumber you may want to consider AssertThat BDD & Test Management in Jira plugin which provides end-t-end BDD/cucumber solution. From interactive gherkin editor to test automation frameworks integration and uploading cucumber reports back to Jira.
More information can be found on the website and wiki.
Glib
I found this one to be better can't remember where I found it
* Author: Michael Hall
* URL: http://www.bankofcanada.ca/
* License: GPL-2 | GPL-3
SyntaxHighlighter.brushes.Gherkin = function()
* Filters out the delimiters and values out of tables.
* @param match: the contents of the matching text
* @param regexInfo: regular expression info
* @returns: list of SyntaxHighlighter.Match objects
function processTable(match, regexInfo){
return [
new SyntaxHighlighter.Match('|',match.index,'keyword'),
new SyntaxHighlighter.Match(match[0].substr(1),match.index+1,'value')
var keywords = 'Given When And Then Feature Scenario Outline Template Background But Examples';
this.regexList = [
{ regex: SyntaxHighlighter.regexLib.singleLinePerlComments, css: 'comments' }, // comments using #
{ regex: SyntaxHighlighter.regexLib.doubleQuotedString, css: 'string' }, // "string"
{ regex: /"""[^"]*"""/gm, css: 'string' }, // multiline string (""" ..... """)
{ regex: /\b([\d]+(\.[\d]+)?|0x[a-f0-9]+)\b/gi, css: 'value' }, // numbers
{ regex: new RegExp(this.getKeywords(keywords), 'gmi'), css: 'keyword' }, // keywords
{ regex: /@[^@\r\n\t ]+/gi, css: 'preprocessor' }, //annotations
{ regex: /\|.*?(?=\|)/g, func: processTable }, //Tables
{ regex: /\|/g, css: 'keyword' }, //Excess table delimiters
{ regex: /(<|<).*?(>|>)/gi, css: 'value' } //values from tables
SyntaxHighlighter.brushes.Gherkin.prototype = new SyntaxHighlighter.Highlighter();
SyntaxHighlighter.brushes.Gherkin.aliases = ['gherkin', 'behat'];
Found the following ticket: https://jira.atlassian.com/browse/CONFCLOUD-69840
Aside from this cool workaround let's all also vote for getting the feature into the standard code macro.
Sorry - my bad, the Prism plugin was not properly installed. I was just getting regular Jira code macro functionality.
@Andreas according to their documents it does https://prismjs.com/#languages-list
But on applying it with:
{code:gherkin}.. {code}
I get
Unable to find source-code formatter for language: gherkin. Available languages are: actionscript, ada, applescript, bash, c, c#, c++, cpp, css, erlang, go, groovy, haskell, html, java, javascript, js, json, lua, none, nyan, objc, perl, php, python, r, rainbow, ruby, scala, sh, sql, swift, visualbasic, xml, yaml
Which is only a fraction of the claimed supported formats.
Thanks for the interesting suggestion, @Glib .
We're running JIRA on premises though and are currently not looking for additional tools in that technology stack.
