Gliffy Images not showing?
Joseph Wibowo
May 21, 2019 edited
Anyone else struggle with using attached custom images in a gliffy diagram? It just shows up as an invisible box.
Same problem here: https://community.atlassian.com/t5/Marketplace-Apps-Integrations/Adding-images-to-Gliffy/qaq-p/1018627
The fact this is an issue is quite surprising. This functionality is core to the product.
John Almeida
May 29, 2019 edited
Scott's advice it dead on! We hope this helped resolve your issue, but If you are still running into this problem, submit a ticket to our support team here.
Scott Theus
May 21, 2019
Hi @Joseph Wibowo
What is the size and file type of the image you are attaching?
Joseph Wibowo
May 21, 2019
tried jpg and png, small file, just a couple hundred pixel square img
Scott Theus
May 21, 2019
Is it less than 1 MB?
This may or may not help, but here is the documentation on using attached images:
https://guide.gliffy.com/user-manual/gliffy-for-confluence-plugin/1/en/topic/adding-images?q=image+attach
Register now
