I am struggling to create a stacked bar graph based on a simple chart.
I am able to create the graph in Excel, but it seems like there is no way to do something similar in Confluence. See below for Excel chart as well as Confluence settings I'm currently trying.
Excel:
Confluence Chart Settings:
Confluence Output:
I've tried to do smth similar and the macro seems to be working fine for me:
To change your X axis from Dep to PC/Notebook, change the "Content Orientation" from horizontal to vertical.
Our company also develops the Table Filter and Charts for Confluence app, so if it happens so that you have the add-on installed for your instance, you may try the Chart from Table macro instead.
Creating graphs is not possible natively in Confluence. However, there are a lot of apps in the marketplace that will have the same charts and graphs.
With our app Excellentable spreadsheet for Confluence, you can create a chart just the way you do in Excel/Google Sheets. You can also import an excel with charts directly into Confluence.
Regards
Shardul Juyal
