Help with spacing within a dropdown user macro for tables Dalectric
Michael
February 10, 2020
Hello everyone,
I'm using a drop down user macro who's code was originally added into the community by @Dalectricbut I'm having issues with the spacing underneath my "inputs" for this dropdown user macro. (All letters that hang under the baseline get cut off)
Example:
I've tried to look through the code for the fix but I can't seem to find anything that points to the dimensions of the dropdown itself. If anyone can help me resolve this issue, I'd be greatful.
User Macro Code:
## @param DropdownId:title=Unique dropdown ID|type=string|required=true|default=1|desc=If more than one dropdown in page, change this to a unique name.
## @param Label:title=Label|type=string|desc=Enter dropdown label, if desired
#set ( $dropdownId = "" )
#set ( $dropdownId = "dropdown-" + $paramDropdownId )
#set ( $label = "" )
#set ( $label = $paramLabel )
#set ( $toplabel = "" )
#if ( $label == "" )
#set ( $toplabel = "top-label" )
#end
#set ( $pageId = $content.id )
#set ( $options = $body.split("\n") )
<form class="aui $toplabel">
<div class="field-group">
#if ( $label != "" )
<label for="$dropdownId">$label</label>
#end
<select class="select" id="$dropdownId" name="$dropdownId" onchange="colourFunction()">
#foreach ( $option in $options )
#set ( $option = $option.trim().replaceAll('"', '' ) )
<option value="$option">$option</option>
#end
</select>
</div>
</form>
<script>
AJS.toInit(function() {
var canEdit = true;
#if ( $permissionHelper.canEdit($userAccessor.getUserByName($req.remoteUser), $content) )
jQuery("#$dropdownId").change(function() {
var dropdownObject = this;
jQuery.ajax({
url: contextPath + "/rest/api/content/${pageId}/property/${dropdownId}",
success: function(dropdownData) {
dropdownData.value = jQuery(dropdownObject).val();
dropdownData.version.number += 1;
jQuery.ajax({
contentType: 'application/json',
type: 'PUT',
data: JSON.stringify(dropdownData)
error: function(response) {
var dropdownData = {};
dropdownData.key = "$dropdownId";
jQuery.ajax({
type: 'POST',
url: contextPath + "/rest/api/content/${pageId}/property",
#else
canEdit = false;
#end
jQuery.ajax({
jQuery("#$dropdownId").val(dropdownData.value);
if (!canEdit) {
jQuery("#$dropdownId").prop( "disabled", true );
</script>
Thank you!
Michael
Elena Ovdienko _Stiltsoft_
Hello @Michael ,
I can suggest an easy way to create dropdowns in Confluence for any user, with no technicals skills required. Try our Handy Macros for Confluence app. It has many features, like Handy Status, Handy Reminder, Handy Tasks, Handy Timestamp, and others. For your use case Handy Status could be a perfect fit as it allows to create dropdowns in a few clicks and use them across many Confluence pages.
