×Hi,
I noticed that I can customize the sidebar, header and footer in Confluence 5.10.
I would like to add a livesearch macro in the header, but when I paste this, it is displayed as such:
<ac:structured-macro ac:macro-id="eeede5a3-a0bd-4a99-b7ca-5aa3f5e8043b" ac:name="livesearch" ac:schema-version="1">
<ac:parameter ac:name="spaceKey">
<ri:space ri:space-key="bqc"/>
</ac:parameter>
</ac:structured-macro>
Any help with this?
Thanks.
You should be able to get it to work by inputting it in the old wiki markup format:
{livesearch:spaceKey=bqc}
The alignment might be off because the header is set to be center-aligned, but it should still work.
I tried that with the Metadata 2 Plugin (https://comalatech.jira.com/wiki/spaces/META/overview), but the stuff is not rendering when I put for example this in the main.vmd file:
{space-metadata-from:Release-Version}
Do you have any ideas how to accomplish rendering stuff from the Metadata 2 Plugin in a Velocity file?
Using the suggested {livesearch:spaceKey=xxx} works great in the header. I'm wondering if there is a way to get just that macro to have its standard alignment for search results, rather then retaining the space header center alignment.
It appears that adding {livesearch:spaceKey=xxx} to the header no longer works, at least not for me. No search box is displayed in header, although I can add it to pages just fine.
We are having a similar issue. When we use the above referenced way to add macros, we get an error stating that the macro can't be found.
