In Confluence 3, it was easy to adjust the width of the dashboard panels.
I want to switch to the new layout in Confluence 4, but the left panel is only about 30% of the screen width. See screenshot.
I have some quite long space names, so the right side of the screen is almost empty.
There's a parameter in the default layout called infoPanelWidth, but I can't find any infomation about it.
#set ($infoPanelWidth = $params.get("infopanel-width"))
Can anyone help?
John
Not sure whether the infoPanelWidth parameter is still in use, but you could insert the following CSS in Browse => Confluence Admin => Stylesheet to adjust the width of the left and the right dashboard column:
div.dashboard .dashboard-group.left { width: 50%; } div.dashboard .dashboard-group.right { width: 50%; }
Hope this helps
Thanks a 100 million! :)
