×Hi Community,
as a newbie I have two questions:
While editing a page when I start content with { I can jump into the makrobrowser, choose CODEBLOCK, insert the desired parameters and get it into the page.
Is there a way to
a) save those special edited codeblock e.g. under a new name to have it handy the next time I want to use it or do I have to go this way every time when I insert a similiar codeblock?
b) How do I get this saved & customized macro codeblock_userdefined into the dropdown-list when I type in a {
Thanks for your support,
Marcus
Specifically with the {code} macro, there is functionality built in to the Confluence Admin Console that allows you to change the default behaviour of the macro for all users:
You should be able to achieve this with User Macros.
See http://confluence.atlassian.com/display/DOC/Writing+User+Macros and related pages for more info on this.
Mark
