How can we create a Project Plan in Confluence
Juned Shaikh
I am looking for a project Plan with a Gantt Chart.that can help me to provide a Critical Path Method on the Project Plan as the activities are scheduled automatically.
Also, the notes section should be structured in such a way, it should make the Project Plan look presentable.
If we have any existing samples of the project plan and anyone can share, that would be great.
Thank you!
Juned Shaikh
3 votes
Andrey Khaneev _StiltSoft_
March 25, 2019
Hello Juned,
There as an article about Gantt charts in Confluence. Hope it will help.
Juned Shaikh
This helps, it tells you how you can create an gantt chart. I wish we had a video around it
Juned Shaikh
Actually, Let me try and work with the tool this might just be the answer. thank you!
Juned Shaikh
@Andrey Khaneev _StiltSoft_
I am getting errors as incorrect date format and I am not able to fix it.
can you help here?
March 28, 2019
Yes, what do you see there?
Juned Shaikh
Like • Oluwatobi Owolabi likes this
March 28, 2019
Remove "Activity" column from "Values column" field and select "Start date" and "End Date" columns there.
Juned Shaikh
It is fixed. Thank you!
Like • 4 people like this
Dave Theodore [Coyote Creek Consulting]
Confluence is a documentation system, not a PPM system.
We find that most people use Jira and Confluence together to meet their project management and reporting needs.  They track their issues in Jira, indicate progress, set dates, effort, indicate blockers, etc there.  This information is easily aggregated in Confluence by embedding Jira gadgets in to Confluence pages.  There are a number of Gantt apps available for Jira, some of which have Dashboard Gadgets that you could embed in to Confluence pages. I hope that helps point you in the right direction.
Takafumi Ohtake -Ricksoft-
February 1, 2022 edited
Hi everyone!
Using Gantt Chart Planner for Confluence is another option.
And, an article Plan Projects and Roadmaps with Gantt Charts in Confluence Cloud summarizes the pros and cons of various ways to draw Gantt charts in Confluence Cloud.
It might be helpful even though you use Confluence Server/DC.
I hope it helps you.
