How do I disable the 'Help' link in my edit label window?
Deleted user February 27, 2018 edited
Hi there!
I need to disable the 'Help' link in my edit label window, anybody know how? I am using Confluence 6.1.3.
See the screenshot below for more info:
Any help would be appreciated.
Mahesh S
February 27, 2018
I couldn't see the Help option in my JIRA 7.5 version.
However, if you are using self hosted JIRA, you can write a javascript to hide it. Find a field in the view screen and write a javascript in the 'Description' of the field in Field Configuration. Dont forget to mention the view screen's Div Class name, Pop up label div class name in the IF conditions.
Hi Mahesh,
I am actually using Confluence 6.1.3.
Hope that helps
