How do I move my plugins from my Confluence test environment to my Confluenc production environment?
Diana Bianco June 25, 2020
So, I've been using the sdk to make plugins as the tutorial describes. My question is how do I move these plugins made with the sdk into the production environment I've created?
Nic Brough -Adaptavist-
June 25, 2020
When you build a plugin ready to be spun up in a test environment, the build creates a plugin object, usually a .jar file, sometimes a .obr.  You can add those to your production system via "manage apps -> upload"
See inside
