×This question is in reference to Atlassian Documentation: Code Block Macro
I have some XML that I want to show in a code block. An element in this XML happens to have an attribute that is a URL. For example:
<add key="SomeUrl" value="https://example.com" />
I don't want the URL to be clickable. Any way to do this?
Does it need to be a code block? When I want pure vanilla, I use the no format macro. The URL will not be clickable.
Code Block
<add key="CNN" value="https://www.cnn.com" />
No Format
But then you lose syntax highlighting. Although in my particular case, that would be quite acceptable since my XML snippet has only four lines. I'd rather do without syntax highlighting than have reader accidentally open link when attempting to select text for copy/pasting.
@Peter Milakovich automatic links in code is also extremely undesirable at my company too, especially when documenting our api. There are a number of links that trigger actions such as tracking counts etc and it is a problem.
This should be controllable at least by adding a css style to each page or code block.
This code block behavior creates a catch-22 for code snippets with URLs. You can only get Confluence's "double-click to select code" behavior with a code block macro, not with No Format. But you can only prevent these automatic links with No Format, not Code Block. If you have a Code Block with a code snippet including a long URL, there will be a large part of the area where the user sees a "double-click to select code" tooltip, but the user's click will navigate the browser away from the confluence page, because of the automatic link.
agreed, this can be very annoying especially when the links have "effects"
I don't think it is possible without changing the code block marco code.
There are other ways to achieve similar formatting visualization, but if you want the code block I am afraid this is how it works.
