How do I replace default confluence 5 dashboard with subspaces plugin?
Sorin Sbarnea (Citrix)
February 2, 2014
I am looking for a solution to replace the default list of spaces from confluence 5 with the one generated by the subscpaces plugin, so people will not see the subspaces as listed.
MadelineBarr
June 4, 2014
We find the Subspace plugin useful and use Subspaces Dashboard Panel (CF 4).
The only problem with deactivating the module "global-entities-panel" is that it also removes the Favourite section as well as the space list. User cannot view their list of favorite pages.
I'm thinking of leaving the "global-entities-panel' enabled and using custom HTML to hide the default space list.
For example, at the end of the HEAD:
<style type="text/css">
div#spaces-pane div.space-list-section.entity-list-section.global-spaces-section {
display:none;
</style>
If anyone can see an issue with doing this let me know.
Bill Martin June 5, 2014
Hello Madeline,
there's no reason for concern.
Bill Martin
Communardo Support
MadelineBarr
June 8, 2014
Thanks Bill.
Communardo Administrator
February 3, 2014
Hi Sorin,
go to your Confluence Administration -> Manage Addons -> Subspace Plugin and activate the Module "Subspaces Dashboard Panel (CF 4)". Now you have the Subspace Panel on your Dashboard.
If you want to remove the Confluence original "dashboard space view" you have to deactivate the module "global-entities-panel" which is part of the "Dashboard Macros Plugin" (it is a system plugin).
I hope this helps to clarify your question.
Greetings, Stephanie
Stephanie Hoffmann - Communardo
February 3, 2014
Hi Sorin,
