We have a need to do reviews of design documentation in Confluence using Crucible. This used to be supported, how can I do it in the latest version?
For reference:
There appears to be no plans to add this capability. The ticets have been closed as "won't fix". This is unfortunate.
However, we came up with a workaround. This involves a somewhat manual process and the use of the "Talk" plug-in which allows in-line comments and the commenting on the end of the page. You could also add a workflow plug-in, but we chose to use a JIRA ticket to represent the "document" and use the workflow there.
